Invoke-NcSSH does not work after upgrade to OnCommand Workflow Automation 5.1
- 159
- Visibility:
- Public
- Votes:
- 0
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- om
- Last Updated:
Applies to
OnCommand Workflow Automation (WFA) 5.1
Issue
- Using the powershell 'Invoke-NcSSH' no longer works and causes the workflow to fail
- Testing directly the command on WFA will always return an error exception, even if the ONTAP command succeeded
- The following errors can be seen on
<InstallDrive>\NetApp\WFA\jboss\standalone\log\server.log
2020-06-01 11:25:15,118 ERROR [stderr] (Thread-521 (ActiveMQ-client-global-threads)) [Fatal Error] :1:1: Content is not allowed in prolog.
2020-06-01 11:25:15,212 ERROR [org.jboss.as.ejb3.invocation] (Thread-521 (ActiveMQ-client-global-threads)) WFLYEJB0034: EJB Invocation failed on component WorkflowExecutionJobExecutorImpl for method public abstract void com.netapp.wfa.engine.job.WorkflowExecutionJobExecutor.execute(com.netapp.wfa.engine.job.WorkflowJob,int): javax.ejb.EJBException: ScriptExecutionException{Message: , Cause: null}
