We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
How to use IBM Cognos configuration application to edit “Supported ciphersuites” setting to remove 3DES”
212
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
OnCommand Insight
OnCommand Insight server does not support the use of DES or 3DES ciphers and is not considered vulnerable to CVE-2016-2183. However, the OnCommand Insight Data Warehouse component includes IBM Cognos 10.2.2 which supports DES ciphers, by default. These ciphers can be removed by editing the list of 'Supported ciphersuites' within the IBM Cognos Configuration application.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
