How to import a Cognos Certificate Authority (CA) signed certificate into OnCommand Data Warehouse 7.3.2 and prior
Applies to
OnCommand Insight Data Warehouse (DWH) 7.3.0 to 7.3.2
OnCommand Insight Data Warehouse (DWH) 7.2.x
This article describes the steps required to create and import an IBM Cognos Certificate Authority (CA) signed certificate into the OnCommand Insight Data Warehouse in versions 7.3.2 and prior.
In instances where only the Cognos Reporting Portal must be configured to use CA-signed certificates and the certificates of the administration portal are not important, please follow IBM Cognos Documentation.
