NetApp Knowledge Base
How to determine if AIQUM files failed deployment on vApp/OVA and RHEL
1,001
Visibility:
Votes:
1
Category:
oncommand-unified-manager
Specialty:
legacy
Last Updated:
Applies to
  • Active IQ Unified Manager (AIQUM) Version Independent
  • OnCommand Unified Manager (OCUM) Version Independent
  • OnCommand Performance Manager (OPM) Version Independent
Procedure
How to determine if *.war and/or *.ear files failed deployment or were actively undeployed
  1. Access a root prompt.
  • For Virtual Machine deployments you will need to enable the diag user using the steps outlined in KB: How to access ActiveIQ Unified Manager Virtual Machine (OVA) DIAG shell, then switch to root using the command: sudo su -
  • For Red Hat Enterprise Linux (RHEL), take the appropriate steps to get a root prompt.  This may be different per environment.
  1. Execute these commands:
    ls -la /opt/netapp/essentials/jboss/standalone/deployments/
    For example:
  2. Output from an impact UM 7.3RC1 RHEL instance:
    [root@um ~]# ls -la /opt/netapp/essentials/jboss/standalone/deployments/
    total 545892
    drwxr-xr-x 4 jboss jboss 4096 Jan 12 09:53 .
    drwxr-xr-x 7 jboss jboss 4096 Jan 12 09:21 ..
    drwxr-xr-x 3 jboss jboss 4096 Jan 12 09:20 datasources.war
    -rw-r--r-- 1 jboss root 222 Jan 12 09:53 datasources.war.failed
    -r--r--r-- 1 root root 193653963 Oct 23 09:50 dfm-app.war
    -rw-r--r-- 1 jboss root 222 Jan 12 09:53 dfm-app.war.failed
    -r--r--r-- 1 root root 352602041 Oct 23 09:50 dfm-report-app.ear
    -rw-r--r-- 1 jboss root 222 Jan 12 09:53 dfm-report-app.ear.failed
    -r--r--r-- 1 root root 9881686 Oct 23 09:51 dfm-script-plugin.war
    -rw-r--r-- 1 jboss root 222 Jan 12 09:53 dfm-script-plugin.war.failed
    -rwxr-xr-x 1 jboss jboss 2785507 Oct 23 02:22 mega-app.ear
    -rw-r--r-- 1 jboss root 222 Jan 12 09:53 mega-app.ear.failed
    drwxr-xr-x 4 jboss jboss 4096 Oct 23 02:22 mega-schema.war
    -rw-r--r-- 1 jboss root 222 Jan 12 09:53 mega-schema.war.failed
    -rw-r--r-- 1 jboss jboss 8869 Feb 17 2017 README.txt
    [root@um ~]#
    Note: Not all will show as failed or undeployed. It may be only one file.
