NetApp Knowledge Base
HDS data source performance collection fails intermittently in OCI
87
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight 7.3.9 (OCI)
  • HDS data source
Issue
  • Performance collection of HDS data source fails in OCI with errors like bellow found in acq.log
2020-07-31 19:37:21,440 ERROR [DSM-pool-3-thread-39698] com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource (AggregatedDataSourceErrorsException.java:142) -      Error 1 out of 1: HDS [External process run timed out] - External command timed out after 240 seconds: "D:\Program Files\SANscreen\java64\bin\java" -classpath "c:\export\lib\JSanExportLoader.jar" -Xmx512m -Dmd.command=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_hdsexpcmd_xxx.xxx.xxx.56.txt -Dmd.logpath=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_2020_07_31_19_32_59_623_expOutDir_xxx.xxx.xxx56 sanproject.getexptool.RJElMain ([Device name 443317]: External command timed out after 240 seconds: "D:\Program Files\SANscreen\java64\bin\java" -classpath "c:\export\lib\JSanExportLoader.jar" -Xmx512m -Dmd.command=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_hdsexpcmd_xxx.xxx.xxx.56.txt -Dmd.logpath=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_2020_07_31_19_32_59_623_expOutDir_xxx.xxx.xxx56 sanproject.getexptool.RJElMain)
com.onaro.sanscreen.acquisition.process.error.ProcessTimeoutException: External command timed out after 120 seconds: "D:\Program Files\SANscreen\java64\bin\java" -classpath "c:\export\lib\JSanExportLoader.jar" -Xmx512m -Dmd.command=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_hdsexpcmd_xxx.xxx.xxx.56.txt -Dmd.logpath=D:\Program Files\SANscreen\acq\log\runtime\HDS\storageperformance_1596213179591\recording_2020_07_31_19_32_59_623_expOutDir_xxx.xxx.xxx56 sanproject.getexptool.RJElMain
    at com.onaro.sanscreen.acquisition.process.AcqProcessManager$AcqProcessRunner.call(AcqProcessManager.java:405) ~[hds_hicommand.jar:?]
    at com.onaro.sanscreen.acquisition.process.AcqProcessManager$AcqProcessRunner.call(AcqProcessManager.java:223) ~[hds_hicommand.jar:?]
    at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_231]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_231]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_231]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_231]
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
