Failed to restore database backup in OnCommand Workflow Automation
- 120
- Visibility:
- Public
- Votes:
- 0
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- om
- Last Updated:
Applies to
OnCommand Workflow Automation (WFA) 4.2
Windows 2012
Issue
Database backup restore is failing in OnCommand Workflow Automation server with below error
Error:- Failed restoring 'H:\WFA_V4.2.0.0.1_B4759965_08_13_19__02_01_25.zip'. Caused by BackupAndRestoreException{Message: Failed to restore configuration from 'tmp_3575630945841443123WFA_V4.2.0.0.1_B4759965_08_13_19__02_01_25.zip', Cause: java.lang.RuntimeException: Failed to execute MySql command 'mysql.exe' with arguments: [-e, source E:/Program Files/NetApp/WFA/jboss/standalone/tmp/wfa/1565753403212/backup.sql, -f]}
