NetApp Knowledge Base
Failed to login to ONTAP System Manager with a custom role in ONTAP 9.7 or later
2,491
Visibility:
Votes:
2
Category:
oncommand-system-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP 9.7
  • ONTAP 9.8
  • ONTAP 9.9.1
  • ONTAP 9.10.1
  • NetApp ONTAP System Manager (System Manager)
  • SAML Authentication
  • Custom roles
Issue
  • The error HTTP 401 - Unauthorized appears when you try to login to System Manager
  • When using SAML to log into System Manager, the following error is seen:
    SAML Service Provider
    Authorization Failed
    Based on the information provided to this application about you, you are not authorized to access the resource at "/sysmgr/v4/"
  • An error appears in the MGWD.log. See the KB How to collect System Manager logs from ONTAP
    Tue Jun 02 2020 08:37:12 +02:00 [kern_mgwd:info:2077] 0x84479ce00: 0: ERR: Tables:web: Role '<custom-role>' is not authorized to access web service 'security' on vserver 4568743357: entry doesn't exist
    Wed Jun 29 2022 20:36:17 -04:00 [kern_mgwd:info:2847] 0x8347a0500: 0: ERR: Tables:web: Role '<custom-role>' is not authorized to access web service 'sysmgr' on vserver 4294967295: entry doesn't exist
New to NetApp?
Scan to view the article on your device
