We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
WFA backup restore failed with error "Failed restoring 'WFA_V4.2.0.0.1"
26
Visibility:
Votes:
0
Category:
oncommand-workflow-automation-wfa
Specialty:
om
Last Updated:
Applies to
Workflow Automation (WFA) 4.X
Workflow Automation (WFA) 5.X
Issue
WFA Backup restore failed with below error
Failed restoring 'WFA_V4.2.0.0.1_B4759965_03_24_21__02_01_20.zip'
Caused by: WFLYEJB0447: Transaction 'Local transaction (delegate=TransactionImple < ac, BasicAction: 0:ffff9f2a64b9:31d0f5b8:605ed82c:9caac status: ActionStatus.ABORTED >, owner=Local transaction context for provider JBoss JTA transaction provider)' was already rolled back
Restore logs gives success message, only in WFA GUI error is present
2021-03-29 08:35:23,323 INFO [com.netapp.wfa.backupandrestore.DbRestorerImpl] (default task-19) About to restore database from: 'backup.sql' ...
2021-03-29 08:39:08,409 INFO [com.netapp.wfa.backupandrestore.DbRestorerImpl] (default task-19) Database restored from: 'backup.sql'
2021-03-29 08:39:47,362 INFO [com.netapp.wfa.backupandrestore.DbRestorerImpl] (default task-19) Successfully restored WFA backup from file : tmp_8858801675621007016BackupResourceWFA_V4.2.0.0.1_B4759965_03_24_21__02_01_20.zip
Able to restore successfully in lab setup.
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
