Certain ONTAP data sources fail after upgrading OnCommand Insight to SP8
Applies to
OnCommand Insight SP8+
ONTAP 9.5+
Issue
- Certain ONTAP data sources fail after upgrading OnCommand Insight to SP8 with the following error:
<?xml version='1.0' encoding='UTF-8' ?>
<!DOCTYPE netapp SYSTEM 'file:/etc/netapp_gx.dtd'>
<netapp version='1.150' xmlns='http://www.netapp.com/filer/admin'>
<results reason="Insufficient privileges: user 'netapp\svc_oci' does not have write access to this resource" status="failed" errno="13003"/></netapp>
<<< RESPONSE END >>>
Automatically Lookup Netgroupsoption is enabled on affected datasources, which is non-default
