NetApp Knowledge Base
Can DFM be used to monitor maxdirsize is reached events?
269
Visibility:
Votes:
2
Category:
oncommand-unified-manager-core-package
Specialty:
legacy
Last Updated:
Applies to
  • OnCommand Unified Manager Core Package 5.x
  • Data ONTAP 7-Mode
Answer
DFM has the events:
  • maxdirsize-limit-nearly-reached
  • maxdirsize-limit-reached
In order to alert on this, DFM needs to be configured as a traphost for the controller. When the event occurs in Ontap it will notify DFM via snmp which will generate the event.
To configure DFM as a traphost for the controller.
  1. controller> snmp traphost add <IP address of the DFM server>.
  2. controller> snmp init 1
You will then need to confirm an alarm based on the events.
Additional Information
What is maxdirsize?
