After upgrade to OnCommand Workflow Automation 5.1.x the authentication over LDAP does not work anymore
- 754
- Visibility:
- Public
- Votes:
- 0
- Category:
- oncommand-workflow-automation-wfa
- Specialty:
- legacy
- Last Updated:
Applies to
- OnCommand Workflow Automation ( WFA ) 5.1RC1
- OnCommand Workflow Automation ( WFA ) 5.1.1
- Microsoft Windows Server
Issue
After Upgrading OnCommand Workflow Automation to version 5.1.x the LDAP authentication fails, more specifically LDAP is affected.
- Error in wfa_ldap.log
2020-03-04 09:40:34,381 ERROR [com.netapp.wfa.ldap.LdapWrapper] (default task-5) Failed to find user in LDAP: javax.naming.CommunicationException: qbitdcp001.operation.lan:636 [Root exception is java.lang.NullPointerException]...
- Error in wfa.log
2020-03-04 09:40:34,350 WARN [com.netapp.wfa.common.ssl.SslCertificateUtils] (default task-5) Failed during SSLCertificateUtils:getKeyStore: java.io.EOFException
at java.base/java.io.DataInputStream.readInt(DataInputStream.java:397)
at java.base/com.sun.crypto.provider.JceKeyStore.engineLoad(JceKeyStore.java:700)
at java.base/java.security.KeyStore.load(KeyStore.java:1479)
at deployment.wfa-0.5.ear.common- .....
