NetApp Knowledge Base
Unified Manager cluster removal stuck with the description "Deletion in progress"
2,215
Visibility:
Votes:
1
Category:
active-iq-unified-manager
Specialty:
OM
Last Updated:
Applies to
  • OnCommand Unified Manager (OCUM) 9.5 and below
  • Active IQ Unified Manager (AIQUM) 9.6+
Issue
  • Unable to delete cluster(s) from Unified Manager
  •  Cluster removal process stuck displaying "Deletion in progress" on the "Configuration/Cluster Data Sources" page
Cluster removal process stuck displaying Deletion in progress
  • Collecting a support bundle, or directly looking at the collected log ocumserver.log, will have the following entry:
ERROR [admin] [default task-5] [c.n.o.r.m.e.GlobalExceptionHandler] /rest/datasources/12 com.onaro.sanscreen.acquisition.sessions.AcquisitionUnitException [177-153]
Fail Stop report from Originator:12
Caused by: com.onaro.sanscreen.acquisition.sessions.AcquisitionUnitException: Fail Stop report from Originator:12
If the Cluster is already decomissioned or changed you might see another error because it does not even start acquisition.
Server_mega.log
2019-06-25 07:23:28,595 ERROR [ServerService Thread Pool -- 390] c.n.o.n.e.EmsZapiManager (EmsZapiManager.java:740) - Failed to call system-get-version -- : java.io.IOException: The host [cluster name] not be resolved
New to NetApp?
