ActiveIQ Unified Manager will not authorize adding a cluster via HTTPS or switching to HTTPS
Applies to
- Active IQ Unified Manager 9.6+
- OnCommand Unified Manager 6.x/7.x
Issue
- Adding a cluster displays the following message:
Authorize <hostname or IP> host
Host <hostname or IP> you specified has identified itself with a self signed certificate that has expired. Therefore, you cannot proceed.
- Switching from HTTP to HTTPS displays the following message:
<hostname or IP> cannot be contacted. Enter a valid host name or cluster management IP address, protocol and port.
