Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
"Index 0 out of bounds for length 0" message seen when adding SolidFire cluster in WFA 5.1
326
Visibility:
Votes:
0
Category:
not set
Specialty:
om
Last Updated:
Applies to
  • Workflow Automation (WFA) 5.1
  • Compatible linux-based platforms
Issue
When attempting to add a new SolidFire cluster into WFA 5.1 from the Settings (Gear icon in the top-right corner of the UI > Credentials menu), WFA will fail to add the cluster and displays the message Index 0 out of bounds for length 0.
The Save button will be disabled and grayed out as a result of the error, in to prevent the user from saving the new cluster into WFA.
Additional log observations:
  1. When attempting to add the SolidFire cluster with the hostname, the following message may be seen within the  LOG_WFA.LOG log file within a WFA AutoSupport.
Note: The wfa log file is also present available on <installed_WFA_path>\Program Files\NetApp\WFA\jboss\standalone\log\wfa.log in Windows-based platforms and  /opt/netapp/wfa/jboss/standalone/log.war/jboss/wfa.log in Linux-based platforms.
2020-04-22 00:57:15,428 ERROR [com.netapp.wfa.ui.ExecutionFacadeImpl] (default task-52) Failed to resolve the host name 'FQDN-OF-WFA' to IP address.
  1. Similarly when providing the IP address of the SolidFire cluster as a credential and clicking on the Test button, WFA will record the following (false-positive) message in wfa.log. Despite what the error message below states, SolidFire cluster will have unexpired SSL certificates upon verification.
Credential with expired certificate is not testable.
New to NetApp?
Scan to view the article on your device
