NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
Why is the Switch Alias not appearing as expected in OCI or Cloud Insights?
47
Visibility:
Votes:
0
Category:
cloud-insights
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI)
  • Cloud Insights (CI)
  • Brocade Switch
Answer
  • Each Brocade SSH/CLI datasource has a field "Choose Favoring HBA vs Zone Aliases".
    • Default is "HostBusAdapter".
    • When using HostBusAdapter OCI and CI will prefer to report as Switch Alias.
    • OCI/CI will perform a best attempt at parsing the hostname from the switch alias data for that WWNN.
  • When using Zone Aliases, OCI will collect zone information from the switch.
    • OCI will perform a best attempt at parsing the hostname from the zonealias data for that WWNN.
  • There is not much standardization for what metadata gets sent to the FC Name Server table
    • Some hosts (most Windows and Linux) will send their HBA model, firmware, driver data, and often the simple hostname.
    • Other hosts (HPUX, etc) only send hostname and OS version.
    • OCI/CI makes a best effort to parse this data to report HBA details.
  • What OCI pulls for hostname from the FC Name Server may be more accurate than manually created switch aliases within Brocade FOS.
    • If the switch alias column is empty, the switch alias is not defined on the brocade switch.
    • To resolve this the admin can change Brocade datasources from HostBusAdapter to ZoneAlias
Additional Information
additionalInformation_text
Scan to view the article on your device
