Effective December 3 - NetApp adopts Microsoft’s Business-to-Customer (B2C) identity management to simplify and provide secure access to NetApp resources. For accounts that did not pre-register (prior to Dec 3) access to your NetApp data may take up to 1 hour as your legacy NSS ID is synchronized to the new B2C identity. To learn more, Read the FAQ and Watch the video.
NetApp Knowledge Base
OnCommand Insight HPE XP8 storage array datasource not polling performance
54
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
OnCommand Insight 7.3.x
HPE XP8 Storage array
Issue
Datasource sample log shows:
2020-07-16 10:49:29,207 ERROR [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource] HPE_Array_LS5T2XP8ORA358_XP8_CmdView_TASPMOKCCV104 - 0 out of 1 devices acquired successfully.
2020-07-16 10:49:29,207 ERROR [com.onaro.sanscreen.acquisition.framework.datasource.BaseDataSource]   Error 1 out of 1: HPE_Array_LS5T2XP8ORA358_XP8_CmdView_TASPMOKCCV104 [Failed to execute external utility] - Error executing export utility ([Device name 33287]: Export utility path: D:\HP_Export_Utilities\90_04_01\lib does not point to a directory)
com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException: Error executing export utility
 at com.onaro.sanscreen.acquisition.framework.datasource.DataSourceErrorException.createWithEnhanced(DataSourceErrorException.java:47) ~[au.jar:?]
 at com.onaro.sanscreen.acquisition.storageperformance.hds.expExecutor.ExportUtilityRecordingHandler.validateConfigParams(ExportUtilityRecordingHandler.java:89) ~[hds_hicommand.jar:?]
 at com.onaro.sanscreen.acquisition.storageperformance.hds.BaseRecordingHandler.run(BaseRecordingHandler.java:66) ~[hds_hicommand.jar:?]
 at com.onaro.sanscreen.acquisition.storageperformance.hds.expExecutor.ExportUtilityCollector.run(ExportUtilityCollector.java:120) ~[hds_hicommand.jar:?]
 at com.onaro.sanscreen.acquisition.storageperformance.hds.HDSStoragePerformance$QueryPerformanceTask.call(HDSStoragePerformance.java:372) ~[hds_hicommand.jar:?]
 at com.onaro.sanscreen.acquisition.storageperformance.hds.HDSStoragePerformance$QueryPerformanceTask.call(HDSStoragePerformance.java:355) ~[hds_hicommand.jar:?]
 at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_212]
 at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_212]
 at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_212]
 at java.lang.Thread.run(Thread.java:748) [?:1.8.0_212]
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
