The NetApp Knowledge Base Site will be down for 60 minutes on August 13, 2022, from 8 PM to 9 PM PT for system maintenance and infrastructure update.
OnCommand Insight Data Warehouse reporting portal is not accessible - refused to connect
315
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight Data Warehouse 7.3.10 +
Issue
When trying to access the OnCommand Insight Data Warehouse reporting portal you receive the following error.
This site can’t be reached
dwh-reporting.server.com refused to connect.
  • When trying to start DB2 - DB2COPY1 - DB2-0 service you receive the following error.
The DB2 - DB2COPY1 - DB2-0 service failed to start due to the following error:
The service did not start due to a logon failure.
  • The Windows Event Viewer - System shows the following error
The DB2REMOTECMD_DB2COPY1 service was unable to log on as .\db2admin with the currently configured password due to the following error:
Logon failure: the user has not been granted the requested logon type at this computer.
Or
The DB2-0 service was unable to log on as .\db2admin with the currently configured password due to the following error: The password for this account is expired.
  • The below error can resolved by adding db2admin  account to the local Windows Administrator group
The DB2 - DB2COPY1 - DB2-0 service failed to start due to the following error: Access is denied
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
