OnCommand Insight Cisco Switch Data Source Resolution Guide
Applies to
- OnCommand Insight (OCI)
- Cloud Insight
- Cisco Switch Data Source
Resolution
This resolution guide a collection of known issue is intended to assist with troubleshooting OnCommand Insight Cisco Switch data source.
OnCommand Insight Cisco Data Source Setup |
Please use Cisco Provided Document to create local SNMP User in Cisco Switch Just as a Reference, Cisco Document for Cisco Nexus 7000 Series, Configuring SNMP User |
Cisco FC Switch (SNMP) data source setup in OCI Please use the same SNMP USER you created on Cisco Switch when setup a Cisco data source in OCI server |
Troubleshoot SNMP Communication |
Did you check if SNMP port is open? |
How to run OnCommand Insight's SNMPwalk to troubleshoot SNMP communication |
Cisco SNMP Counters |
Cisco SNMP Counter [Port Metrics] |
Troubleshooting Cisco NVP Switch |
The OnCommand Insight Java client does not show all switches listed in the web interface |
Additional Information
additionalInformation_text
