NetApp Knowledge Base
OnCommand Insight: What are Ontap commands for troubleshooting switches?
55
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight switch data source troubleshooting
  • Ontap
Answer
Data ONTAP switch commands used to troubleshoot OnCommand Insight switch datasource
Commands Expected Command Function
fc show adaptor: Shows information about FC target ports configuration
fcadmin config:  Sets behavior of onboard FC ports as initiators or targets
fcp config: Shows information about FC target ports configuration
fcp show initiator: Shows host initiators currently connected to the storage system
fcp show nodename: Shows FC nodename currently assigned to the storage system
fcp show/set cfmode: Shows cfmode being used on the storage system
options: Shows global configuration settings on the storage system
Additional Information
additionalInformation_text
Scan to view the article on your device
