Effective December 3 - NetApp adopts Microsoft’s Business-to-Customer (B2C) identity management to simplify and provide secure access to NetApp resources. For accounts that did not pre-register (prior to Dec 3) access to your NetApp data may take up to 1 hour as your legacy NSS ID is synchronized to the new B2C identity. To learn more, Read the FAQ and Watch the video.
NetApp Knowledge Base
OCI - DWH connector issue ETL is timing out
155
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
om
Last Updated:
Applies to
  • OnCommand Insight 7.3.8 (OCI)
  • OnCommand Insight DataWareHouse 7.3.8 (DWH)
  • Both Linux and Windows installation
Issue
  • The DWH connector to the OCI server is failing.
  • The bellow is shown in the connector's page in DWH.
43606 Inventory: connector 'Connector_name', '18-Jun-2020 00:00' FAILED 18/06/20 05:01 18/06/20 11:28
43582 Inventory: connector 'Connector_name', '17-Jun-2020 00:00' FAILED 17/06/20 06:34 17/06/20 06:45
43570 Inventory: connector 'Connector_name', '16-Jun-2020 17:35' FAILED 16/06/20 17:35 16/06/20 23:49
  • Multiple erros can be found in dwh.log like the bellow:
    • 2020-06-23 11:19:15,690 ERROR [Thread-694 (ActiveMQ-client-global-threads)] JobDispatcherBean (JobDispatcherBean.java:106) - InventoryJob{name='Inventory: connector 'Connector_Name', '23-Jun-2020 00:00'', id=43727, connectorId=9, targetTime=1592866800057, current=true} failed
      com.netapp.sanscreen.dwh.applications.inventory.InventoryException: Failed running inventory job
      Caused by: com.netapp.sanscreen.dwh.applications.inventory.InventoryException: Failed to execute SQL script com/netapp/sanscreen/dwh/inventory/processors/performance/performance_summary.load.sql
      Caused by: com.netapp.sanscreen.dwh.util.SqlShellException: Failed to execute: INSERT IGNORE INTO dwh_inventory_transient.volume_performance SELECT pt.id AS volumeId, cl.global_id AS storageId, i.sampleTime, i.readResponseTime, i.writeResponseTime, i.totalResponseTime, i.totalResponseTimeMax, i.readThroughput, i.writeThroughput, i.totalThroughput, i.totalThroughputMax, i.readIops, i.writeIops, i.totalIops, i.totalIopsMax, i.readCacheHitRatio, i.writeCacheHitRatio, i.totalCacheHitRatio, i.totalCacheHitRatioMax, i.writePending, i.readIoDensity, i.writeIoDensity, i.totalIoDensity, i.totalIoDensityMax, i.accessed FROM dwh_inventory_staging.tmp_volume_performance i JOIN dwh_inventory_staging.chassis_local cl ON cl.connector_id = 9 AND cl.local_id = i.storageId AND cl.type = 'storage' JOIN dwh_inventory.volume pt ON pt.storageId = cl.global_id AND pt.name = i.name
      Caused by: java.sql.SQLException: IJ031012: Unable to obtain lock in 60 seconds: org.jboss.jca.adapters.jdbc.local.LocalManagedConnection@7be69125
    • 2020-06-12 11:09:19,253 ERROR [Thread-186 (ActiveMQ-client-global-threads)] SqlShell (SqlShell.java:943) - <OCI_host> Failed to close JDBC connection
      com.mysql.jdbc.exceptions.jdbc4.MySQLNonTransientConnectionException: Communications link failure during rollback(). Transaction resolution unknown.
    • 2020-06-18 11:28:08,505 ERROR [Thread-450 (ActiveMQ-client-global-threads)] JobDispatcherBean (JobDispatcherBean.java:106) - InventoryJob{name='Inventory: connector 'Connector_Name', '18-Jun-2020 00:00'', id=43606, connectorId=9, targetTime=1592434800062, current=true} failed
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
