Known issues that can cause installation failure of Data WareHouse; Resolution Guide
- 118
- Visibility:
- Public
- Votes:
- 0
- Category:
- oncommand-insight-data-warehouse
- Specialty:
- oci
- Last Updated:
Applies to
Data WareHouse (DWH) installation
Solution
This KB article contains hyperlinks to known issues that can cause installation or upgrade issues for Data Warehouse Server
Verify the Windows host meets basic minimum requirement |
Make sure the Windows OS meets OCI server minimum requirements
Make sure all of the Ports outlined in the DWH Minimum requirements are available on the Windows host. |
Check that the Windows Page File is configured |
Ensure Windows driver is installed that allows MYSQL Database to operate |
AntiVirus Exclusions |
The OCI installation directory must be excluded from Antivirus software scans |
Use the correct user when installing DWH |
Windows user must have Administrator privileges, as outlined in the OCI WIndows installation instructions |
Linux User must have SUDO privileges, as outlined in the Linux installation instructions |
Local and domain policies prevent installation |
Check local and domain policies to ensure the configuration does not prevent DWH installation |
Data WareHouse install fails to due to password complexity in Windows local policy |
OCI_DWH_fails_to_install_due_to_non_English_system_local_settings |
OnCommand Insight Data Warehouse install fails when the local Administrator group is denied access from the network |
OnCommand Insight Data Warehouse installation fails at "Starting Reporting Engine" step, with error "There is a problem with this Windows Installer package" |
DWH DB2 user / service prevents DWH install |
Data WareHouse Installtion issues caused by DB2 User or DB2 services Resolution Guide |
Installation Drive configuration prevents installation |
OnCommand Insight Data Warehouse 7.3.X install fails because 8dot3 naming convention is not enabled on the installation drive |
Multiple install attempts |
OCI_DWH_fails_due_to_remnants_on_the_file_system |
If installation issues are not resolved by the articles in this resolution guide, Collect Logs from the Data Warehouse and open a NetApp Technical Case for further assistance.
Additional Information
Known issues that can cause installation failure of OnCommand Insight; Resolution Guide
