Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
How does the OnCommand Insight and Cloud Insights discover all fabric switches feature work with Brocade switches?
92
Visibility:
Votes:
0
Category:
cloud-insights
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI)
  • Cloud Insights (CI)
  • Brocade Switch
Answer
  • The OCI / CI data source will SSH to the switch you specify in the data source configuration.
  • OCI / CI will inventory that switch and perform a fabricShow command.
    • With the fabric discovery feature enabled, OCI will parse the fabricShow output looking for MAC Adress of switches
    • OCI / CI will try to determine the WWN of the switch if it is a Brocade device.
  • After inventorying the first Brocade switch, the data source will then move to SSH-ing to the next Brocade switch it has learned about.
Scan to view the article on your device
