NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
ElasticSearch indexing failures cause performance issues in OnCommand Insight
708
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.x
Issue
Issues that may be related to failed indexing in ElasticSearch are listed below. These may be seen together or separately.
  • Slow WebUI searches
  • High CPU usage on the OCI server
  • High Memory usage on the OCI server
  • File system near full/full on the OCI server
  • 404 Page Not Found error message when trying to access the WebUI
  • Datasources failing with error "Internal error: Cannot update server (Server returned HTTP response code: 500 for URL"
In the server_indexer.log (located in \SANscreen\wildfly\standalone\log) you may see failed index messages similar to:
2018-01-15 20:35:00,436 ERROR [EJB default - 7] QueryIndexBuilder (QueryIndexBuilder.java:195) - Error indexing InternalVolume
 com.netapp.oci.es.ElasticsearchException: [bulkIndexById][INDEX_NAME:oci-inventory-internalvolume-2018-01-15-20-33] [ANOMALY_INDEX_TYPE: internalvolume] [IDS: [7864440,
 Caused by: com.netapp.oci.es.ElasticsearchException: Error bulk indexing data. failure in bulk
execution:
 [19439]: index [oci-inventory-internalvolume-2018-01-23-07-56], type [internalvolume], id [11609
24], message [java.lang.IllegalArgumentException: Document contains at least one immense term
in field="annotationValues.text.Automounter Path" (whose UTF8 encoding is longer than the max l
ength 32766), all of which were skipped. Please correct the analyzer to not produce such terms. T
he prefix of the first immense term is: '[47, 105, 99, 101, 110, 103, 47, 100, 102, 109, 47, 114, 103,
98, 44, 32, 47, 105, 99, 101, 110, 103, 47, 100, 102, 109, 47, 98, 108, 97]...', original message: by
tes can be at most 32766 in length; got 37802]
In server.log (located in \SANscreen\wildfly\standalone\log) you may see failed messages similar to:
2019-06-18 07:11:26,296 ERROR [default task-33057] OriginatorWorkingSet(OriginatorWorkingSet.java:488) - <datasource> failed on submit, due to: Errors encountered while executing delete extendedData documents. failure in bulk execution:
[0]: index [oci-extended-data-v2], type [_doc], id [1871197], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[1]: index [oci-extended-data-v2], type [_doc], id [3310508], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[2]: index [oci-extended-data-v2], type [_doc], id [1567170], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[3]: index [oci-extended-data-v2], type [_doc], id [4478203], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
[4]: index [oci-extended-data-v2], type [_doc], id [4311330], message [ClusterBlockException[blocked by: [FORBIDDEN/12/index read-only / allow delete (api)];]]
In the oci-cluster.log (located in \SANscreen\program_data\elasticsearch\logs) you may see failed messages similar to:
[2018-03-26T17:55:13,054][WARN ][o.e.c.a.s.ShardStateAction] [<datasource>] [oci-timeseries-qtree-2018-03-11][1] received shard failed for shard id [[oci-timeseries-qtree-2018-03-11][1]], allocation id [sSKYeTqNR46jrWY-rGw1XA], primary term [0], message [failed recovery], failure [RecoveryFailedException[[oci-timeseries-qtree-2018-03-11][1]: Recovery failed on {XXXXXXXX}{6HO5LMOIRYCEAWKINLSCIQ {TB2VITKTREOZQLBQLXWMIG}{127.0.0.1}{127.0.0.1:9310}]; nested: IndexShardRecoveryException[failed recovery]; nested: IllegalStateException[pre-1.4 translog found [F:\NetApp\SANscreen\program_data\elasticsearch\data\nodes\0\indices\KeESoUKHROaLhn6_WseZVQ\1\translog\translog-1.tlog]]; ] org.elasticsearch.indices.recovery.RecoveryFailedException: [oci-timeseries-qtree-2018-03-11][1]: Recovery failed on {XXXXXXXX}{6HO5LMOIRYCEAWKINLSCIQ}{TB2VITKTREOZQLBQLXWMIG}{127.0.0.1}{127.0.0.1:9310}
Caused by: org.elasticsearch.index.shard.IndexShardRecoveryException: failed recovery
 at org.elasticsearch.index.shard.StoreRecovery.executeRecovery(StoreRecovery.java:299) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.StoreRecovery.recoverFromStore(StoreRecovery.java:88) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.IndexShard.recoverFromStore(IndexShard.java:1238) ~[elasticsearch-5.4.2.jar:5.4.2]
 at org.elasticsearch.index.shard.IndexShard.lambda$startRecovery$1(IndexShard.java:1486) ~[elasticsearch-5.4.2.jar:5.4.2]
 ... 4 more
Caused by: java.lang.IllegalStateException: pre-1.4 translog found [F:\NetApp\SANscreen\program_data\elasticsearch\data\nodes\0\indices\KeESoUKHROaLhn6_WseZVQ\1\translog\translog-1.tlog]
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
