OnCommand Insight Data Warehouse ETL job fails at "DatamartsPreparation" caused by "Duplicate entry '#-12345-#' for key'PRIMARY
- 148
- Visibility:
- Public
- Votes:
- 1
- Category:
- oncommand-insight-data-warehouse
- Specialty:
- oci
- Last Updated:
Applies to
- OnCommand Insight Data Warehouse (DWH) 7.3.x
- OnCommand Insight (OCI) 7.3.x
- NetApp StorageGRID
Issue
When either your Scheduled Extract, Transform, Load (ETL) process or manual execution within the DWH web interface fails at the 'Datamarts Preparation' job
Clicking the 'FAILED' red hyperlink will show an error message similar to the following:
com.netapp.sanscreen.dwh.capacity.CapacityException: Failed running pre capacity job Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException:Duplicate entry '#-12345-#-#-#' for key 'PRIMARY'
will contain the following error message:
2018-08-08 08:10:09,953 ERROR [Thread-65 (ActiveMQ-client-global-threads)] SqlShell(SqlShell.java:1303) - Failed to insert row into dwh_capacity_staging.storage_and_storage_pool_capacity_fact due to unique keyPRIMARY[storagePoolTk, storageTk, tierTk, backend, isVirtual] and values 0-88217-0-0-0[0, 88217, 0,0, 0]. Query: INSERT INTO dwh_capacity_staging.storage_and_storage_pool_capacity_fact
Showing the duplicate records: storagePoolTk,storageTk,tierTk,backend,isVirtual,capacityMB,rawCapacityMB,usedCapacityMB,usedRawCapacityMB,snapshotUsedCapacityMB,snapshotUsedRawCapacityMB,softLimitCapacityMB,unconfiguredRawCapacityMB,spareRawCapacityMB,failedRawCapacityMB,volumeCapacityMB,unusedVolumeCapacityMB,volumeConsumedCapacityMB,mappedVolumeCapacityMB,maskedVolumeCapacityMB,internalVolumeAllocatedCapacityMB,internalVolumeUsedCapacityMB,internalVolumeConsumedCapacityMB,dedupeRatio,compressionRatio
0,88217,0,0,0,0,247281042,0,0,0,0,null,247 281042,0,0,0,0,0,0,0,0,0,0,null,null
0,88217,0,0,0,0,7922254,0,7922254,0,0,null,0,0,0,0,0,0,0,0,0,0,0,null,null
2018-08-08 08:10:14,540 ERROR [Thread-65 (ActiveMQ-client-global-threads)] JobDispatcherBean(JobDispatcherBean.java:106) - Job{name='Datamarts Preparation', id=29970} failed com.netapp.sanscreen.dwh.capacity.CapacityException: Failed running pre capacity job
Checking the database on the DWH server shows that 12345 is associated with the IPaddress of your StorageGRID datasource:
- On the DWH server, open a command prompt with elevated privileges (Run AsAdministrator)
- Run
cd
InstallationDrive:Program Files\SANscreen\mysql\bin
- Run
mysql.exe -uroot -p
- Enter the password for your DWH database
- Run
select * from dwh_dimensions.storage_dimension where tk = 12345
