NetApp Knowledge Base
Cognos scheduled reports fail after password update: CM-REQ-4159 CM-CAM-4005 Unable to authenticate
1,475
Visibility:
Votes:
0
Category:
oncommand-insight-data-warehouse
Specialty:
oci
Last Updated:
Applies to
  • OnCommand Insight (OCI) 7.3.x
  • IBM Cognos
Issue
  • After logging on to IBM Cognos Connection successfully after a password change, previously scheduled reports will fail, while other non-scheduled reports will run successfully during this session.
  • Following error message will be observed when scheduled reports fail:
CM-REQ-4159 Content Manager returned an error in the response header. The error "cmAuthenticateFailed CM-CAM-4005 Unable to authenticate. Check your security directory server connection and confirm the credentials entered at login" can be found in the response SOAP header. CM-REQ-4342 An error has occurred with the client.
New to NetApp?
Scan to view the article on your device
