NetApp Knowledge Base
Which REST API or CLI is equivalent to Capacity in ONTAP System Manager Dashboard?
946
Visibility:
Votes:
2
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
ONTAP System Manager 9.7 or later
Answer
Capacity in ONTAP System Manager Dashboard shows sizes of USED and AVAILABLE.
REST API and CLI to obtain these values are:
  • REST API for USED
[<CLUSTER>/api/storage/cluster?fields=*]
  • CLI for USED
::*> storage aggregate show-efficiency -aggregate <AGGREGATE> -fields aggregate,total-logical-used,total-physical-used,aggr-logical-used,aggr-physical-used,total-storage-efficiency-ratio
Note: Advanced privilege is required.
  • REST API for AVAILABLE
[<CLUSTER>/api/storage/aggregates?fields=space,space.block_storage.inactive_user_data,*]
  • CLI for AVAILABLE
::> df -A
Example:
Results of REST API and CLI corresponding to the above screenshot(USED is 7.32 MB, AVAILABLE is 28.32 GB).
  • REST API for USED
[cluster2/api/storage/cluster?fields=*]
<snip>
"efficiency": {
    "savings": 0,
    "ratio": 1,
    "logical_used": 7671808
</snip>
Logical_used: 7671808 == 7671808/1024/1024 == 7.32 MB
  • CLI for USED
::*> storage aggregate show-efficiency -aggregate aggr1_cluster2_01 -fields aggregate,total-logical-used,total-physical-used,aggr-logical-used,aggr-physical-used,total-storage-efficiency-ratio
aggregate                 total-logical-used     total-physical-used     total-storage-efficiency-ratio     aggr-logical-used     aggr-physical-used
aggr1_cluster2_01     7.32MB                     13.83MB                     1.00:1                                         13.83MB                   13.83MB
total-logical-used = 7.32 MB
[cluster2/api/storage/aggregates?fields=space,space.block_storage.inactive_user_data,*]
Only Data Aggregates (No Root Aggregate):
<snip>
"space": {
"footprint": 25886720,
"block_storage": {
    "size": 30439669760,
    "available": 30404370432,
    "used": 35299328,
    "full_threshold_percent": 98
</snip>
Available Space: 30404370432/1024/1024/1024 == 28.32 GB
  • CLI for AVAILABLE
::> df -A
Aggregate                           kbytes               used          avail         capacity
aggr1_cluster2_01             29726240     34332       29691908       0%
aggr1_cluster2_01/.snapshot  0                  0              0                   0%
Available Space: 29691908 == 29691908/1024/1024 == 28.32 GB
Additional Information
additionalInformation_text
