System Manager Cluster Guided Setup Templates
Applies to
- ONTAP 9.X
- System Manager
- System Manager provides a Guided Setup feature that can use a pre-populated template file. Setting up a cluster by using the template file
- Completed template files used in the cluster setup may be retained for setup/configuration documentation purposes.
