NetApp Knowledge Base
Does ONTAP System Manager support direct file upload for disk or shelf firmware?
1,379
Visibility:
Votes:
1
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
ONTAP System Manager 9.8 and newer
Answer
A feature to directly upload disk firmware, shelf firmware, SP/BMC firmware and the disk qualification package (DQP) is available in ONTAP System Manager 9.8 and later versions. Starting with ONTAP 9.9.1, you can receive alerts in System Manager from Active IQ Unified Manager that inform you when firmware updates are pending on the cluster.
To access this feature in System Manager:
  1. Cluster -> Overview.
  2. Click More (3 dots) in the top right corner of the Overview page and select ONTAP Update from the drop-down menu.
  3. Navigate to the Firmware Update tab.
Additional Information
Update firmware in ONTAP 9
