NetApp Response to Russia-Ukraine Cyber Threat
In response to the recent rise in cyber threat due to the Russian-Ukraine crisis, NetApp is actively monitoring the global security intelligence and updating our cybersecurity measures. We follow U.S. Federal Government guidance and remain on high alert. Customers are encouraged to monitor the Cybersecurity and Infrastructure Security (CISA) website for new information as it develops and remain on high alert.
NetApp Knowledge Base
Cannot provision aggregate in ONTAP System Manager with newly deployed cluster
531
Visibility:
Votes:
1
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
  • ONTAP System Manager 9.8P9 and earlier
  • ONTAP System Manager 9.9.1P2 and earlier
  • ONTAP 9.8P9 and earlier
  • ONTAP 9.9.1P2 and earlier
Issue
  • Unable to provision an aggregate from either Node 1 or Node 2 using ONTAP System Manager.
  • Prepare Storage fails by error:
Job failed to complete. Reason: No recommended aggregates could be created. Failed to provision aggregate on nodes: <NODE>.
  • Manual provisioning works via the ONTAP CLI.
Cluster-1::*> aggr create -aggregate Cluster_1_01_SAS_1 -encrypt-with-aggr-key true -disktype SAS -raidtype raid_dp -maxraidsize 11 -diskrpm 10000 -pool Pool0 -diskcount 11 -chksumstyle bloc
 Info: The layout for aggregate "Cluster_1_01_SAS_1" on node "Cluster-1-01" would be:
       First Plex
         RAID Group rg0, 11 disks (block checksum, raid_dp)
                                                             Usable Physical
           Position   Disk                      Type           Size     Size
           shared     1.0.21                    SAS               -        -
           shared     1.0.5                     SAS               -        -
           shared     1.0.7                     SAS          1.61TB   1.61TB
           shared     1.0.9                     SAS          1.61TB   1.61TB
           shared     1.0.11                    SAS          1.61TB   1.61TB
           shared     1.0.13                    SAS          1.61TB   1.61TB
           shared     1.0.15                    SAS          1.61TB   1.61TB
           shared     1.0.17                    SAS          1.61TB   1.61TB
           shared     1.0.19                    SAS          1.61TB   1.61TB
           shared     1.0.3                     SAS          1.61TB   1.61TB
           shared     1.0.1                     SAS          1.61TB   1.61TB
       Aggregate capacity available for volume use would be 13.05TB.
 Do you want to continue? {y|n}: y
 [Job 1020] Job succeeded: DONE
  • Auto-provisioning via the ONTAP CLI fails.
Cluster-1::> aggr auto-provision -verbose
Per node summary of new aggregates to create, discovered spares, and also
remaining spare disks and partitions after aggregate creation:
                     New    Total New -Discovered Spare- -Remaining Spare-
Node               Aggrs  Usable Size  Disks  Partitions  Disks Partitions
Cluster-1-01           1      13.05TB      0          12      0          1
Cluster-1-02           1      13.05TB      0          12      0          1
Total:                 2      26.10TB      0          24      0          2
Cluster-1::> storage aggregate show-auto-provision-progress
                                  Current       Target
Aggregate                     Usable Size  Usable Size Provisioning Progress
Cluster_1_01_SAS_1                     0B      13.05TB Failed
Cluster_1_02_SAS_1                     0B      13.05TB Failed
Error: Provisioning "Cluster_1_01_SAS_1" failed. Reason: [Job 452] Job failed: Failed to create aggregate "Cluster_1_01_SAS_1" on
       "Cluster-1-01". Reason: There are not enough spare disks with matching RPM. 11 disks needed from one pool, but not enough matching
       disks of the requested size are available in either pool.
       Provisioning "Cluster_1_02_SAS_1" failed. Reason: [Job 453] Job failed: Failed to create aggregate "Cluster_1_02_SAS_1" on
       "Cluster-1-02". Reason: There are not enough spare disks with matching RPM. 11 disks needed from one pool, but not enough matching
Scan to view the article on your device
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
