NetApp Knowledge Base
Connection shutdown error after upgrading the NetaApp Manageability SDK to newer versions
142
Visibility:
Votes:
0
Category:
netapp-manageability-sdk
Specialty:
core
Last Updated:
Applies to
  • NetApp Management SDK 5.3.1 or later
  • 7-Mode Systems
Issue
After upgrading the NetApp Management SDK (NM-SDK) to version 5.3.1 or newer, API calls start failing with error:
javax.net.ssl.SSLException: Connection has been shutdown: javax.net.ssl.SSLHandshakeException:
  • Server chose SSLv3, but that protocol version is not enabled or not supported by the client
  • SSL is enabled in the 7-Mode System
  • TLS is disabled in the 7-Mode System
New to NetApp?
Scan to view the article on your device
