What is the maximum configurable SSD cache size on E-Series storage systems?
- 1,160
- Visibility:
- Public
- Votes:
- 2
- Category:
- e-series-santricity-storage-manager
- Specialty:
- esg
- Last Updated:
Applies to
E-Series Systems with SSDs to be used with SSD cache.
Answer
- Maximum amount of configurable SSD cache for an array is related to the controller's primary cache size.
- This chart shows the amount of SSD cache configurable for various primary cache size of the controllers:
Controller Cache Size | Configurable SSD Cache Size |
< 1 GB | 1 TB |
> 1 GB - 2 GB | 2 TB |
> 2 GB - 4 GB | 4 TB |
> 4 GB | 5 TB |
Additional Information
- Controller's primary cache size will be smaller than the controller installed memory size
- The size difference will vary depending on the release version and array configuration.
- Current maximum is 5TB of SSD cache for any system configuration.
- Primary cache size is equal to the cache of one controller in a redundant array.
- Example: An array with two 2600 controllers with 2 GB of cache each will only be able to configure 2 TB of SSD cache.
