What are the network ports utilized by an E-Series array?
Applies to
E-Series
Answer
See the registered service names and ports for reference: Service Name and Transport Protocol Port Number Registry
1.E2800/E5700/newer (embedded WebServices managed by SANtricity System Manager):
Service Name | Port | Port Configurable | Direction | Protocol | Description |
ssh | 22 | No | Inbound | TCP | Remote login |
http |
80 8080 |
No | Inbound | TCP | Redirects to port 8443 |
https |
443 8443 |
No | Inbound | TCP | System Manager / REST API |
lsi-raid-mgmt | 2463 | No | Inbound | TCP | Legacy management |
lsi-raid-mgmt | 2463 | No | Inbound | UDP | Legacy auto-discovery |
snmp | 161 | No | Inbound | UDP | SNMP Agent |
http | 80 | No | Outbound | TCP | ASUP dispatch via HTTP direct |
https | 443 | No | Outbound | TCP | ASUP dispatch |
http/https | Yes | Outbound | TCP | ASUP dispatch | |
syslog | Yes | Outbound | TCP/UDP | syslog for alerts | |
snmptrap | 162 | No | Outbound | UDP | SNMP traps |
ntp | 123 | No | Outbound | UDP | Network Time |
domain | 53 | No | Outbound | TCP/UDP | Domain name |
smtp | 25 | No | Outbound | TCP | Email alerts / ASUP dispatch via email |
kmip | Yes | Outbound | TCP | External Key Management |
ldap/ldaps | Yes | Outbound | TCP | LDAP authentication |
2.E2700/E5600/earlier (managed by SANtricity Storage Manager):
telnet | 23 | No | Inbound | TCP | Remote login |
lsi-raid-mgmt | 2463 | No | UDP | Legacy auto-discovery | |
ntp | 123 | No | Outbound | UDP | Network Time Protocol |
domain | 53 | No | Outbound | TCP/UDP | Domain name resolution |
3.SANtricity Storage Manager:
https | 8443 | No | Outbound | TCP | REST API to storage array |
lsi-raid-mgmt | 2463 | No | Outbound | TCP | Legacy management to storage array |
lsi-raid-mgmt | 2463 | No | Outbound | UDP | Legacy auto-discovery |
https | 443 | No | Outbound | TCP | ASUP dispatch via HTTPS direct, AOD |
http/https | Yes | Outbound | TCP | ASUP dispatch via proxy server or Proxy auto-configuration script (PAC), AOD | |
syslog | 514 | Yes | Outbound | UDP | syslog for alerts |
snmptrap | 162 | No | Outbound | UDP | SNMP traps (alerts) |
4.SANtricity Web Services Proxy:
http | 8080 | Yes | Inbound | TCP | Unified Manager / REST API |
https | 8443 | Yes | Inbound | TCP | Unified Manager / REST API |
https | 443 | No | Outbound | TCP | ASUP dispatch via HTTPS direct |
http/https | Yes | Outbound | TCP | ASUP dispatch via proxy server or Proxy auto-configuration script (PAC) | |
smtp | 25 | No | Outbound | TCP | ASUP dispatch via email |
Note: For the Mirroring function network ports, please follow 9.2 Management Station Port Numbers on Page 40 of TR-4656 SANtricity Synchronous and Asynchronous Mirroring.
Additional Information
Add your text here.
