NetApp Knowledge Base
What are the network ports utilized by an E-Series array?
3,222
Visibility:
Votes:
9
Category:
e-series-santricity-management-software
Specialty:
esg
Last Updated:
Applies to
E-Series
Answer
See the registered service names and ports for reference: Service Name and Transport Protocol Port Number Registry
  1. E2800/E5700/newer (embedded WebServices managed by SANtricity System Manager):
Service Name Port Port Configurable Direction Protocol Description
ssh 22 No Inbound TCP Remote login
http
80
8080
No Inbound TCP Redirects to port 8443
https
443
8443
No Inbound TCP System Manager / REST API
lsi-raid-mgmt 2463 No Inbound TCP Legacy management
lsi-raid-mgmt 2463 No Inbound UDP Legacy auto-discovery
snmp 161 No Inbound UDP SNMP Agent
http 80 No Outbound TCP ASUP dispatch via HTTP direct
https 443 No Outbound TCP ASUP dispatch
http/https   Yes Outbound TCP ASUP dispatch
syslog   Yes Outbound TCP/UDP syslog for alerts
snmptrap 162 No Outbound UDP SNMP traps
ntp 123 No Outbound UDP Network Time
domain 53 No Outbound TCP/UDP Domain name
smtp 25 No Outbound TCP Email alerts / ASUP dispatch via email
kmip   Yes Outbound TCP External Key Management
ldap/ldaps   Yes Outbound TCP LDAP authentication
  1. E2700/E5600/earlier (managed by SANtricity Storage Manager):
telnet 23 No Inbound TCP Remote login
lsi-raid-mgmt 2463 No UDP Legacy auto-discovery
ntp 123 No Outbound UDP Network Time Protocol
domain 53 No Outbound TCP/UDP Domain name resolution
  1. SANtricity Storage Manager:
https 8443 No Outbound TCP REST API to storage array
lsi-raid-mgmt 2463 No Outbound TCP Legacy management to storage array
lsi-raid-mgmt 2463 No Outbound UDP Legacy auto-discovery
https 443 No Outbound TCP ASUP dispatch via HTTPS direct, AOD
http/https   Yes Outbound TCP ASUP dispatch via proxy server or Proxy auto-configuration script (PAC), AOD
syslog 514 Yes Outbound UDP syslog for alerts
snmptrap 162 No Outbound UDP SNMP traps (alerts)
  1. SANtricity Web Services Proxy:
http 8080 Yes Inbound TCP Unified Manager / REST API
https 8443 Yes Inbound TCP Unified Manager / REST API
smtp 25 No Outbound TCP ASUP dispatch via email
Note: For the Mirroring function network ports, please follow 9.2 Management Station Port Numbers on Page 40 of TR-4656 SANtricity Synchronous and Asynchronous Mirroring
Additional Information
Add your text here.
