NetApp Knowledge Base
Why does the sum of all volume IOPS in an aggregate not match the aggregate IOPS?
1,051
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
perf
Last Updated:
Applies to
  • OnCommand Unified Manager (OCUM)
  • Active IQ Unified Manager (AIQUM)
  • ONTAP 9
Answer
  • Volume and Aggregate (disk) layers are two different layers and accounted differently in ONTAP
    • Volume level includes only foreground operations, but aggregate level operations include all background operations and foreground
  • Workloads can present more or less aggregate operations compared to volume operations
    • Examples:
      • A 1 GB file may be read in 1 MB chunks at the protocol level (1 IOP per 1 MB), but requires multiple WAFL read requests on the backend to fill one operation in parallel
      • In the 1 GB file in 1 MB chunk example above, once the first megabyte chunk is read, readahead will predictively fetch the second, third, and so on chunks before the user/application requests the data to improve read performance
      • Data frequently accessed remains cached in RAM and does not require disk access
      • A workload is all writes which are buffered by consistency points, requiring differing levels of disk access for consistency points to flush to disk
  • Another possiblity is that data gets cached that is frequently used, causing more IOPS than the aggregate level
Why may aggregates have different op counts than the volume?
  • There are many background operations ONTAP does which decouple it from volume work
    • Background workloads such as SnapMirror, wafl scanners, deduplication, etc. all take disk IOPS but would not count as a user IOP
    • These are triggered by internal configurations or schedules
    • They are tracked in the internal qos statistics workloads
  • Workloads have different behaviors within ONTAP
    • IOPS get mixed together as requests come in
      • Example: One volume may have 4kB reads, the other 1 MB reads, and there may be write workloads which do not get written to disk until the Consistency Point
    • One IOP on the network may trigger several WAFL IOPS or it may take several IOPS on the network to make one WAFL IOP
How do different IOP types (read, write, other, and small or large IOPS) affect volume IOP counts compared to disk?
  • Reads that read the same data repeatedly are cached after the first hit
  • Readahead will fetch the blocks that are needed before requested, which causes more disk IOPS than volume IOPS
  • Large reads (> 64 kB) have one volume IOP but multiple disk IOPS are merged
  • Writes go through Consistency Points, and are not written to disk
  • Other IOPS that do not modify file system structures generally are in cache
    • Example: A volume may have 100,000 GETATTR IOPS but not use disk to read the data after initial load of workload
  • Other IOPs that do modify file system structures may require several disk IOPS to update metadata and data blocks
    • Example: A SETATTR that overwrites a file has to:
      1. Update metadata
      2. Mark the existing block free
      3. Write new data in Consistency Point on new spot on disk due to WAFL behavior
Should we use these outputs in AIQUM to see if more workload can be added
Additional Information
Example: The sum of all the volumes in the aggregate (under 2,000) do not total the 5,000 aggregate IOPS in AIQUM in the screenshot below
Volume IOPs in an aggregate not match the aggregate IOPs
