What are ActiveIQ Unified Manager’s recording files and how to we parse them for troubleshooting?
Applies to
ActiveIQ Unified Manager.
Answer
Recording files are created at the time that a polling cycle is triggered within ActiveIQ Unified Manager to collected data from the Clustered Ontap Operating System.
- Recording files capture the raw API data that is actually received by ActiveIQ Unified Manager from the cluster.
- Foundation Recording files are created each time inventory Polling is performed.
- Polling is once every 5 minutes by default.
- Performance Recording files are bundled into a ‘one recording per day’ zip file.
- Performance Recording files will contain up to 5 polling cycle samples (Numbered folders) per recording file.
- Recording files provide one or more “Sample.log” file that records the status of the Polling Cycle success or failure.
"Sample.log" file Naming convention: log_LogType_CLUSTERNAME.corp.company.org_91_year_month_day_HR_MIN_SEC_XXX.sample.log
- Recording “sample.log” is usually located within the “root” folder, however it can also reside within the Number folder; check both folders.
How to find Recording files within a Support Bundle
Within a Support Bundle, the recording files are located within folder: Support_bundle_DATE_HR_MIN_SEC\acquisition\recording
Looking for a Storage Performance Recording file that was created on the date that the issue was observed on.
EXAMPLE: netappstorageperformance_CLUSTER01.corp.company.org_01_2019_06_09_08_37_21_665.zip
- How to locate the Sample.log file
- Check the root or numbered folder to identify the Sample.log file.
- Open the sample.log file within any Text editor.
- This sample file will tell you whether the Performance Acquisition was successful, or failed.
- If failed, the error will be captured within the sample.log file.
For convenience, here are examples of the recording file structure, both for netappfoundation and netappstorageperformance.
Netappfoundation:
netappfoundation_xx.xx.xx.xx_3_2019_05_30_11_51_22_243
├───1559242272012
│ description.xml
│ log_netappfoundation_xx.xx.xx.xx_91_2019_05_30_11_51_12_075_iterator_response_times.txt
│ log_netappfoundation_xx.xx.xx.xx_91_2019_05_30_11_51_12_076_zapi_attributes.txt
│ log_netappfoundation_xx.xx.xx.xx_91_2019_05_30_11_51_22_165_poll_time.txt
│ model_netappfoundation_xx.xx.xx.xx_91_2019_05_30_11_51_21_306.xml
│ netappdata_netappfoundation_xx.xx.xx.xx_91_2019_05_30_11_51_21_337_3.xml
│ recording_netappfoundation_xx.xx.xx.xx_91_2019_05_30_11_51_12_074_netappfoundation.dat
└───root
configuration
description.xml
log_netappfoundation_xx.xx.xx.xx_91_2019_05_30_11_51_12_012_sample.log
Netappstorageperformance:
netappstorageperformance_xx.xx.xx.xx_3_2019_05_30_00_28_01_556
├───1559200078025
│ description.xml
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_08_06_225_iterator_response_times.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_08_06_226_zapi_attributes.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_08_09_441_poll_time.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_08_13_303_poll_time.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_08_15_142_poll_time.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_08_25_691_poll_time.txt
│ netappfoundation_xx.xx.xx.xx_3_2019_05_30_00_06_28_852_copy.zip
│ recording_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_08_06_224_netappstorageperformance.dat
├───1559200378012
│ 163185_000300_1559199900886_0270000.ccma.gz
│ 163185_000300_1559199900886_0270000.ccma.md5
│ 163185_000300_1559199900886_0270000.ccma.meta
│ 163382_000300_1559199900552_0282000.ccma.gz
│ 163382_000300_1559199900552_0282000.ccma.md5
│ 163382_000300_1559199900552_0282000.ccma.meta
│ description.xml
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_12_58_014_iterator_response_times.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_12_58_015_zapi_attributes.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_12_59_621_ocie_report_times.txt
│ log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_02_120_poll_time.txt
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_462_WorkloadQueueDBladeCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_495_WorkloadQueueNBladeCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_518_ResourceCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_555_WorkloadDetailCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_651_LifCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_718_NFSv3Counter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_735_WaflCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_763_ProcessorCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_784_DiskConfigCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_796_DiskCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_860_AggregateCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_914_HostadapterCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_920_NicCommonCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_01_983_CifsCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_02_011_NodeCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_02_034_ExtCacheObjCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_02_050_ResourceHeadRoomCPUCounter.csv
│ perfdata_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_13_02_077_ResourceHeadRoomAggrCounter.csv
│ recording_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_12_58_013_netappstorageperformance.dat
├─── <truncated 3 numbered folder outputs>
└───root
configuration
description.xml
log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_07_58_025_sample.log
log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_12_58_012_sample.log
log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_17_58_031_sample.log
log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_22_58_054_sample.log
log_netappstorageperformance_xx.xx.xx.xx_91_2019_05_30_00_27_58_014_sample.log
Additional Information
Within the Storage Performance recording are copies of the CCMA files downloaded from the cluster.
- These CCMA files are not human readable and can only be parsed with special software tools. The CCMA files contain the raw performance data from the cluster.
- The CCMA Files are located within the unix timestamp folder (aka the 'numbered' folder) in the Storage Performance Recording.
- Within each numbered folder, there should be a ccma.gz, a ccma.md5, and a ccma.meta file for each node in the cluster.
- If any of these files are missing, it could mean that Unified Manager did not receive a CCMA file collection from one of the Cluster nodes.
- To save space in the Support Bundle, each daily Performance Recording file only includes 5 CCMA files out of the numerous Performance recordings that are captured throughout the day.
