NetApp Knowledge Base
Unable to add cluster to Active IQ Unified Manager resolution guide
5,895
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • OnCommand Unified Manager (OCUM)
  • Active IQ Unified Manager (AIQUM)
  • ONTAP 9.x
  • When adding a cluster to Active IQ Unified Manager the following errors might occur in the web interface.
    • Host <IP/hostname/FQDN> you specified has identified itself with a self signed certificate for Active IQ Unified Manager that has expired. Therefore, you cannot proceed.
    • <IP/hostname/FQDN> is running an unsupported Data ONTAP version. The minimum supported version is Data ONTAP X.X.X.
    • Unable to add data source, which can be caused by reaching the max number of EMS notification destinations in the data source.
    • Cluster add failed. Cluster <IP/hostname/FQDN> already exists.
    • Invalid login credentials
    • Failed to fetch the HTTPS certificate from xxx.xxx.xxx.xxx. Enter a valid Host name or Port.
    • Failed to fetch the HTTPS certificate from hostname. Enter a valid Host name or Port.
    • Failed to fetch the HTTPS certificate from hostname.prod.org. Enter a valid Host name or Port.
  • Below are a list of known issues and solutions for each
New to NetApp?
