NetApp Knowledge Base
SAML authentication is rejected due to metadata mismatch
1,418
Visibility:
Customer
Votes:
1
Category:
ontap-system-manager
Specialty:
om
Last Updated:
Applies to
  • System Manager 9.7
  • Microsoft ADFS
Issue
  • Unable to authenticate via SAML to System Manager because the IdP metadata does not contain an email address
  • The /mroot/etc/shibboleth/shibd.log contains the following errors:
[kern_shibd:info:9583] ERROR OpenSAML.MetadataProvider.XML : metadata instance failed manual validation checking: EmailAddress must have TextContent
[kern_shibd:info:9583] WARN Shibboleth.SessionInitiator.SAML2 [1] [default]: unable to locate metadata for provider (https://sts.iconplc.com/adfs/services/trust)
Unknown or Unusable Identity Provider The identity provider supplying your login credentials is not authorized for use with this service or does not support the necessary capabilities
New to NetApp?
