Performance archive collection fails in OCUM/AIQUM, because node root volume is not properly mounted on VLDB and WAFL
Applies to
- ONTAP 9
- OnCommand Unified Manager 7.2 and later (UM)
- ActiveIQ Unified Manager 9.6 and later (UM)
Issue
UM fails to download the ccma archive from the cluster SPI. Errors similar to the one below can be found in au.log
, located in /<support_bundle_location>/acquisition/au.log
, or in /var/log/ocie/au.log
Unable to download the archive file from node: <node_name> to path :/var/log/ocie/recording/archiver/: IOException, Failed downloading archived file: https://<cluster_mngmt_LIF>:443/spi//etc/log/stats/ccma/kernel/opm/102010_000300_14 58215701217_0296000.ccma.meta to path: /var/log/ocie/recording/archiver///102010_000300_1458215701217_0296000.ccma.meta (Server returned HTTP response code: 503 for URL: https://<cluster_mngmt_LIF>:443/spi//etc/log/stats/ccma/kernel/opm/102010_000300_145 8215701217_0296000.ccma.meta)) 2016-03-17 14:08:36,949 WARN [pool-2-thread-23957] com.onaro.sanscreen.acquisition.datasource.netapp_ocie.archiver.common.ArchiveFileDownloader (JBossLoggerAdapter.java:203) - : Download wait timed out after: 240000 milliseconds. Null
