NetApp wins prestigious Coveo Relevance Pinnacle Award. Learn more!
INSIGHT Japan :2023年 1月25日(水)ANAインターコンチネンタルホテル開催 へ参加・申込を行う
NetApp Knowledge Base
OnCommand Unified Manager's web interface becomes slow/unresponsive
298
Visibility:
Votes:
0
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
Applies to
  • OnCommand Unified Manager (OCUM) 7.2
  • OnCommand Unified Manager (OCUM) 7.3
  • OnCommand Unified Manager (OCUM) 9.4
  • OnCommand Unified Manager (OCUM) 9.5
  • ActiveIQ Unified Manager (AIQUM) 9.6
  • ActiveIQ Unified Manager (AIQUM) 9.7
  • VMware Vsphere
Issue
  • The OnCommand Unified Manager web interface becomes stale, unresponsive, and stops collecting data from its monitored Clusters
  • Events/alerts are not triggered because the server is barely functioning
  • After rebooting the Virtual Machine instance of OnCommand Unified Manager (vApp), functionality resumes for a relatively short period of time until responsiveness slows down and it needs to be rebooted again
  • In some occasions the AIQUM services may not start at all after a reboot
In Support Bundle's 'jboss' folder, review the 'au_error###.log" file for the following content:
# There is insufficient memory for the Java Runtime Environment to continue.
# Native memory allocation (mmap) failed to map 12288 bytes for committing reserved memory.
# Possible reasons:
# The system is out of physical RAM or swap space
# In 32 bit mode, the process size limit was hit
# Possible solutions: Knowledgebase
# Reduce memory load on the system
# Increase physical memory or swap space
# Check if swap backing store is full
# Use 64 bit Java on a 64 bit OS
# Decrease Java heap size (-Xmx/-Xms)
# Decrease number of Java threads
# Decrease Java thread stack sizes (-Xss)
# Set larger code cache with -XX:ReservedCodeCacheSize=
# This output file may be truncated or incomplete.
# # Out of Memory Error (os_linux.cpp:2643), pid=6920, tid=0x00007f30c27e9700
New to NetApp?
Scan to view the article on your device
