NetApp Knowledge Base
MetroCluster monitoring failed in ActiveIQ Unified Manager with Reason: An internal error has occurred during MetroCluster component refresh due to hex values to the "Reason for Last Reboot" field
1,151
Visibility:
Votes:
3
Category:
oncommand-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager 9.6+
  • Oncommand Unified Manager 6.x/7.x/9.x
  • Metrocluster
Issue
  • In Configuration menu, Cluster Data Sources tab, MetroCluster clusters will have this message in Description column: 'Monitoring failed...'
  • Event created with title 'Event: Cluster Monitoring Failed' and Trigger Condition: 'Monitoring failed for cluster <MetroCluster-CLUSTER>. Reason: An internal error has occurred during MetroCluster component refresh. Contact technical support.'
Collecting a support bundle, or directly looking at collected log 'ocum-error.log', will have the following entry:
"ERROR [oncommand] [collection-completion-0] [c.n.d.i.m.MccFabricConfigDiscoveryHandler] MetroCluster monitoring failed for <MetroCluster-CLUSTER>"
ERROR [oncommand] [reconcile-1] [affhosmc.chkd.net(incremental@13:58:23.999)] [c.n.dfm.collector.OcieJmsListener] Error during MetroCluster component monitoring : com.ctc.wstx.exc.WstxIOException: Invalid UTF-8 middle byte 0xb (at char #34185, byte #31999)
ocumserver.log
ERROR [oncommand] [reconcile-2] [QSCPS040(incremental@00:22:34.950)] [c.n.dfm.collector.OcieJmsListener] Error during MetroCluster component monitoring : MetroCluster component monitoring failed. Zapi execution failed XML processing error during ZAPI call storage-bridge-get-iter to QSCPS040: Invalid UTF-8 middle byte 0xb (at char #34126, byte #31999)
com.netapp.dfm.ontap.outbound.zapi.OcumMonitoringFailedException: MetroCluster component monitoring failed. Zapi execution failed XML processing error during ZAPI call storage-bridge-get-iter to <metrocluster name>: Invalid UTF-8 middle byte 0xb (at char #34126, byte #31999)
This will show up in autosupports or output for the 'Reason for last reboot' for the bridge in the storage-bridge-view.
Critical Hardware Error Detected0xED 0x
or
Critical Software Error Detected0xED 0xB
You can log into AIQ and pull up the cluster by name,serial or system id.
  1. Click on AutoSupport on the left side of the page
  2. Select the node from the drop down.
  3. Click on a weekly autosupport.
  4. Check the storage-bridge-view.xml
  5. Review the 'Reason for last reboot' to confirm.
New to NetApp?
