NetApp Knowledge Base
Active IQ Unified Manager is failing CommVault AuxCopy jobs due to duplicate volume names
73
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
  • Active IQ Unified Manager (UM) 9.x vApp/OVA
  • Commvault 11
Issue
  • During a conformance job within CommVault, an AuxCopy will fail with the following error in the Auxcopy.log file:
10560 32f4  07/27 06:20:15 14157320 ManageONTAPDFMCMode::DFMGetJobStatusForJobId Status for job[1877651232a29721:-51d12425:1738f5823c4:6fb5] is [6]:[Data ONTAP reported error code (17159), message: 'Duplicate volume name CC_volumename_Copy_1253_cluster_AGS_TEST_NR_Backup.' (request: '<volume-create><containing-aggr-name>aggregate_1</containing-aggr-name><size>171578965524 b</size><space-reserve>none</space-reserve><volume>CC_volumename_Copy_1253_cluster_AGS_TEST_NR_Backup</volume><volume-type>dp</volume-type></volume-create>').]
  • The following errors are also seen within the UM server.log file:
2020-08-05 23:41:58,610 ERROR [org.jboss.as.ejb3.invocation] (DefaultQuartzScheduler_Worker-8) WFLYEJB0034: EJB Invocation failed on component UpdateTaskExecuteSessionEJB for method public abstract java.lang.Object com.netapp.oci.server.UpdateTaskExecutor.execute(com.netapp.oci.server.UpdateTask) throws com.netapp.oci.server.UpdateTaskException,com.netapp.oci.server.DeadlockTaskException: javax.ejb.EJBException: WFLYEJB0442: Unexpected Error
Caused by: java.lang.OutOfMemoryError: Java heap space
2020-08-06 00:56:35,031 ERROR [org.jboss.threads.errors] (default task-1111) Thread Thread[default task-1111,5,main] threw an uncaught exception: java.lang.OutOfMemoryError: Java heap space
2020-08-06 00:56:35,031 ERROR [org.jboss.threads.errors] (default task-1102) Thread Thread[default task-1102,5,main] threw an uncaught exception: java.lang.OutOfMemoryError: Java heap space
2020-08-06 00:56:35,030 ERROR [io.undertow.request] (default task-1091) UT005023: Exception handling request to /apis/XMLrequest: java.lang.OutOfMemoryError: Java heap space
2020-08-06 00:59:08,696 ERROR [stderr] (Thread-226) Exception in thread "Thread-226" Exception in thread "Thread-1126 (ActiveMQ-server-org.apache.activemq.artemis.core.server.impl.ActiveMQServerImpl$6@392ba466)" java.lang.OutOfMemoryError: Java heap space
Note: The UM server.log file can be obtained by using the How to Collect Logs article to generate a Support Bundle and located in the jboss directory
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
