NetApp Knowledge Base
ActiveIQ UM upgrade fails with jboss permission errors
81
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
Applies to
ActiveIQ Unified Manager (UM) 9.10 upgrade to 9.10P1
Issue
The upgrade of UM fails with error:
2022-06-29 06:08:48,363 WARN  [org.jboss.jca.core.connectionmanager.pool.strategy.PoolBySubject] (pool-14-thread-1) IJ000604: Throwable while attempting to get a new connection: null: javax.resource.ResourceException: IJ031084: Unable to create connection
Caused by: java.sql.SQLInvalidAuthorizationSpecException: Could not connect to address=(host=localhost)(port=3306)(type=master) : (conn=4269) Access denied for user 'jboss'@'localhost' (using password: YES)
Current charset is windows-1252. If password has been set using other charset, consider using option 'passwordCharacterEncoding'
New to NetApp?
Scan to view the article on your device
