NetApp Knowledgebase
Trident pod on Kubernetes pod is not terminating properly
36
Visibility:
Votes:
0
Category:
trident-kubernetes
Specialty:
snapx
Last Updated:
Applies to
Trident for Kubernetes/Openshift
Issue
The following is shown on listing the trident related pods:
NAME                          READY   STATUS        RESTARTS AGE   IP            NODE              NOMINATED NODE  READINESS GATES
trident-csi-4cbtt             2/2     Running       4        96d   <MASTER_IP_1> caas-master01-01  <none>          <none>
trident-csi-5b59f59cc8-9wqp5  5/5     Running       0        11h   <NODE_IP_11>  caas-node01-01    <none>          <none>
trident-csi-5b59f59cc8-m9tdz  5/5     Terminating   0        12h   <NODE_IP_22>  caas-node02-02    <none>          <none>
trident-csi-dl972             2/2     Running       6        96d   <NODE_IP_22>  caas-node03-03    <none>          <none>
trident-csi-h25g4             2/2     Running       6        96d   <MASTER_IP_1> caas-master03-03  <none>          <none>
trident-csi-nzzgj             2/2     Running       4        96d   <MASTER_IP_1> caas-master02-02  <none>          <none>
While the new trident provisioning pod errors out with:
time="2020-11-30T23:55:58Z" level=error msg="Trident REST interface was not available after 30.00 seconds."
time="2020-11-30T23:55:58Z" level=debug msg="Updating Trident Provisioner CR after failed installation." name=trident
namespace=trident time="2020-11-30T23:55:58Z" level=info msg="'TridentProvisioner' CR updated." name=trident namespace=trident
time="2020-11-30T23:55:58Z" level=error msg="error syncing 'trident/trident': reconcile failed; error re-installing Trident 'trident' in namespace 'trident'; err: reconcile failed;
  unable to upgrade connection: Authorization error (user=kube-apiserver-kubelet-client, verb=create, resource=nodes, subresource=proxy);
  use 'tridentctl logs' to learn more, requeuing"
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
