NetApp Knowledge Base
Trident - OpenShift pods stuck in containerCreating state due to iSCSI session authentication errors
1,066
Visibility:
Votes:
0
Category:
astra_trident
Specialty:
solidfire
Last Updated:
Applies to
  • Trident
  • SolidFire
  • OpenShift 4.4.13+
  • Red Hat Enterprise Linux CoreOS 4.5+
  • Red Hat Enterprise Linux 8.2+
Issue
1. While provisioning pods with NetApp Trident PVCs, pods get stuck in a 'containerCreating' state due to the OpenShift worker nodes being unable to establish an iSCSI session with Element because of a hash algorithm mismatch
2. After upgrading to OpenShift 4.4.13+, existing pods with PVCs are unable to re-establish their iSCSI sessions
The following can be done to confirm this condition:
  • Trident creates the PVC as expected
[root@master k8s]# kubectl get pvc
NAME                           STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS   AGE
persistent-volume-claim-sf     Bound    pvc-7489898e-087b-4db0-b211-e5b254074d56   2Gi        RWO            sf-gold        46h
  • Running iscsiadm -m discovery on the worker node will show the portal is correctly discovered
[root@node-1 iscsi]# iscsiadm -m discovery
192.168.1.50:3260 via sendtargets
iscsiadm -m node will show the target correctly discovered
[root@node-1 iscsi]# iscsiadm -m node
192.168.1.50:3260,1 iqn.2010-01.com.solidfire:3x71.pvc-7489898e-087b-4db0-b211-e5b254074d56.1
  • However, iscsiadm -m session will not show any entries
[root@node-1 ~]# iscsiadm -m session
iscsiadm: No active sessions.
  • Reviewing /var/log/messages on the worker node where the pod resides will show the an authentication error while logging into the target
Jul 30 04:12:36 node-1 iscsid[1372]: iscsid: Login authentication failed with target iqn.2010-01.com.solidfire:3x71.pvc-7489898e-087b-4db0-b211-e5b254074d56.1
Jul 30 04:12:36 node-1 iscsid[1372]: iscsid: Kernel reported iSCSI connection 207:0 error (1020 - ISCSI_ERR_TCP_CONN_CLOSE: TCP connection closed) state (1)
Jul 30 04:12:41 node-1 iscsid[1372]: iscsid: Login failed to authenticate with target iqn.2010-01.com.solidfire:3x71.pvc-7489898e-087b-4db0-b211-e5b254074d56.1
Jul 30 04:12:41 node-1 iscsid[1372]: iscsid: session 207 login rejected: Initiator failed authentication with target
Jul 30 04:12:41 node-1 iscsid[1372]: iscsid: Connection207:0 to [target: iqn.2010-01.com.solidfire:3x71.pvc-7489898e-087b-4db0-b211-e5b254074d56.1, portal: 192.168.1.50,3260] through [iface: default] is shutdown.
New to NetApp?
  • Was this article helpful?
