We are redesigning the NetApp Knowledge Base site to make it easier to use and navigate. The new and improved site will be available the first week of October. Check out our video or read this KB article to know more about changes you’ll see on the site.
Requesting a persistent volume in Trident returns with an EOF error
323
Visibility:
Votes:
0
Category:
trident-kubernetes
Specialty:
snapx
Last Updated:
Applies to
  • Trident for Kubernetes 19.07 and higher
  • Trident for Openshift 19.07 and higher
Issue
The following error ends the PV creation attempt: Post "http://127.0.0.1:8000/trident/v1/backend": EOF
Additional symptoms and behavior seen:
  • worker nodes have full connectivity and resolve all names correctly
  • /etc/resolv.conf in worker nodes have a "search domains" directive, that works as expected
  • pods running on these worker nodes will inherit options and search domains from their host, and add a ndots:5 directive
  • pods only resolve FQDNs, but when removing "ndots:5" or search domains inside the pod, the pod is able to resolve any name
  • apart from name resolution, some destinations are unreachable (ping : no route to host)
  • the kube-apiserver is slow to answer any query with kubectl
  • an ONTAPI https request test to the SVM shows that it's responding normally to, for example a system-get-version API call (*)
CUSTOMER EXCLUSIVE CONTENT
Registered NetApp customers get unlimited access to our dynamic Knowledge Base.
New authoritative content is published and updated each day by our team of experts.
Current Customer or Partner?
Sign In for unlimited access
New to NetApp?
