Cloud Volumes ONTAP instance is running with max CPU utilization on provider's dashboard
Applies to
- Cloud Volumes ONTAP (CVO)
- Amazon Web Services (AWS)
- Microsoft Azure
- Amazon CloudWatch
- ONTAP Select
Issue
- Cloud Volumes ONTAP (CVO) instance is running with 100% CPU utilization in AWS, CLI reports lower CPU usage
- Amazon CloudWatch reports a high CPU warning for the EC2 instance because it sees 100% usage.
- Microsoft Azure Portal dashboard running with near 100% CPU (average) utilization.
- ESXi or vCenter report high CPU for ONTAP Select VM
