NetApp Knowledge Base
What are the minimum Permissions needed for Trident Admin Users when using a SolidFire Backend?
52
Visibility:
Votes:
0
Category:
astra_trident
Specialty:
solidfire
Last Updated:
Applies to
  • Trident
  • SolidFire
Answer
The minimum permissions required for the Trident Administrator User for SolidFire Backends are Accounts and Volumes.
  • Volume access is needed to create the volume.
  • Account permissions are needed to read/set the CHAP credentials for the user account.
Example of Permissions for a Trident Admin within the Element UI under Users > Cluster Admins
Optional privileges are Reporting and Cluster Admin.
  • Cluster Admin is needed if you want trident to be able create the account for you if it doesn’t exist.
  • Reporting is more restrictive than Read access, but still allows API commands related to gathering cluster statistics. This does allow access to a handful of read-only commands that are otherwise only available to ClusterAdmins
Scan to view the article on your device
